October 17, 2019, 09:14:09 pm
Odd SQLite query problem
Started by Scott Slater, December 05, 2013, 04:41:44 pm
Scott Slater
I had a customer contact me that a report was randomly "missing data" and have tracked down the problem to a single SQL query.  the problem is that some items that logically match the WHERE clause don't get selected.  I have put together a reverse logic of that statement below by changing the = to != .  I have attached a very small subset of this clients data that shows the problem.  Using the attached file which contains 4 orders none of which should get selected using the statement below;
SELECT * FROM orders_tbl WHERE (ord_total+discount-tax1-tax2-tax3-tax4-delivery_tax-delivery_fee)!=subtotal;
However, record #1 gets selected.  If you change the != back to an =, then you get the remaining 3.
I have updated to the latest SQLite dll file, and still get this problem with this data set.  I have manually looked at all of the data and did the math and they should all be treated the same way.   Can anyone see a reason or something that I am missing that is causing this issue?
Thanks in advance.
-Scott Slater
December 09, 2013, 09:47:29 am #1 Last Edit: December 17, 2013, 08:29:18 am by cj
It is a rounding issue using floating point numbers.
Solution 1:
select * from orders_tbl where round(ord_total+discount-tax1-tax2-tax3-tax4-delivery_tax-delivery_fee,2)=subtotal;
Solution 2:
Save a penny as 1 and a dollar as 100 is the way I have always handled money.
All INTEGERs and display results multiplied by .01 avoids floating point errors and no rounding is needed.
drop table if exists orders_tbl;
create table if not exists orders_tbl(ord_total,discount,tax1,tax2,tax3,tax4,delivery_tax,delivery_fee,subtotal);
insert into orders_tbl values(38.55, 0, 2.42, 0, 0, 0, .1, 1.5, 34.53);
insert into orders_tbl values(3855, 0, 242, 0, 0, 0, 10, 150, 3453);
select *' from orders_tbl where (ord_total+discount-tax1-tax2-tax3-tax4-delivery_tax-delivery_fee)!=subtotal;
38.55  0  2.42  0  0  0  0.1  1.5  34.53  rounding error
38.55  0  2.42  0  0  0  0.1  1.5  34.53  used round
3855  0  242  0  0  0  10  150  3453     used round
select * from orders_tbl where (ord_total+discount-tax1-tax2-tax3-tax4-delivery_tax-delivery_fee)=subtotal;
3855  0  242  0  0  0  10  150  3453      multiply results by .01
PB test program using ROUND.
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
  LOCAL RowNum,ColNum, columns AS LONG, sResults AS STRING
  slopen "Test.db3","C"
  slexe "CREATE TABLE IF NOT EXISTS ORDERS_TBL(ord_total,discount,tax1,tax2,tax3,tax4,delivery_tax,delivery_fee,subtotal)"
  slexe "INSERT INTO ORDERS_TBL VALUES(38.55,0,2.42,0,0,0,.1,1.5,34.53)"
  slsel "SELECT * FROM orders_tbl WHERE " + _
    "ROUND(ord_total+discount-tax1-tax2-tax3-tax4-delivery_tax-delivery_fee,2)=subtotal"
  columns = slGetColumnCount
  DO WHILE slGetRow
    FOR ColNum = 1 TO columns
      sResults = sResults + slf(ColNum) + "   "
    sResults = sResults + $CRLF
  LOOP
  ? sResults,,"Results"
